AC 2172 update and Teamwork problem
Guys
For quite some time now I had been using AC 9 R1 (1812) without any problems at all. A week ago I decided to upgrade to (2172) since I really needed the billboard trees to cast shadows....something that was not possible with 1812 build..
Anyway after the upgrade I discovered that I couldn't use the Teamwork function.
In the start up dialog the "Sing in to a team project" option was greyed out and the "Teamwork" menu has disappeared. Of course all other commands and functions work perfectly (and yes, tree billboards cast shadows) but still can't use Teamwork.
Since it's a function that I never use I didn't pay much attention.But still can't understand why.
One thing that might be worth considering is that the update installer used greek language(I live in Greece) so I am just wondering if there's a mess up with localised greek version of the update(?) and the INT version of Archicad I have. Don't know for sure if the updates use the system's local language depending on the settings of WIndows since I hadn't updated before.
Any help would be appreciated. Thank you in advance.
0 Replies 0
