ARCHICAD 21 crashes on move command every half an hour
Hi, I have installed ARCHICAD 21 and I am working on the BIM Cloud server which is in another country through VPN connection. Every half an hour ARCHICAD crashes, usually on a move command. Can somebody help?I upgraded the RAM memory of the computer at 32 GB RAM but problem still persists. I even changed the graphics card to a GE FORCE 1650. Please help I have ran out of ideas.
Miha_M
You should create a signature as for which Archicad & what system you are runnig it on.
I don't know if this will help, as it happened to me with Archicad 22, but still worth a try:
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=66748&hilit=permanent+crash
| Archicad 4.5 - 29
Thank you for your response.I am using windows 10 and ARCHICAD 21. However I checked the option suggested in the topic you sent me but the Beta option is not activated in my case. Any other suggestion?May be related with the VPN client?
Miha_M
If Archicad does run in a local environment and doesn't via VPN, then I would assume that the problem solution is to be found in the VPN environment.
But VPN related Archicad behaviour is beyond my work process, that's just a guess.
| Archicad 4.5 - 29
