Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
SOLVED!
Add-ons - 404 page not found
Chris_Lz
Hi, does anyone know what's happening to the add-ons download page, at least in the UK?
I'm trying to select add-ons to download but when I click on them, either I get the error 404 page not found, or it appears the window to login, although I'm already logged in with my ID.
Thanks.
1 ACCEPTED SOLUTION
Solution
Solved this.
It worked fine when using a direct link to download received from the Support team.
It was probably the link from the NBS website to Graphisoft, that was creating the issue.
3 REPLIES 3
Noemi Balogh
Hi @Chris_Lz,
Can you elaborate on which link gives you an error?
Thank you,
Noémi
Noémi Balogh
Senior Community Expert, Admin
I'm trying to download the NBS plugin.
If I click on the link from the NBS website it sends me on the Graphisoft page with the login message 'Please sign in with your ID..', where I get stuck in a loop. I login but it keeps appearing on the same page with login requests.
If I go directly on Archicad's add-ons page, I choose NBS plugin and press 'Find more' I get the message '404 - page not found'.
Solution
Solved this.
