Installation & update
Add-ons
Hi everyone,
I have a simple question but i cant seem to find it anywhere online. I would like to know if the add-ons that I load on my computer at the office will be loaded on all other computers on the BIM-Server from the office, or if this this to be done on all computers individually.
Thanks a lot in advance!
If you are referring to addd-ons such as CADimage, then yes it will need to be installed on all individual computers.
Hey!
Since my Office has a Server, what i did was copy the Add-ons Folder to the Server and in Archicad changed the path to it (it Shows you then the add-ons double, but you can uncheck the old ones and the delete them) so now when we have a new Add-on it will be in all Computers
Im new with archicad so im sitll experimenting a bit!
Thanks for your post though!!
v_amato wrote:
Hey!
Yours is not a recommended solution. Add-ons are actual program code with their own installers/uninstallers and settings files (preferences/registry). They must be updated along with any ArchiCAD program updates/patches - and are only found if they reside in the location within the ArchiCAD program/application folder hierarchy in which they are expected.
(In addition, depending on your workstations and server permissions settings, some components of the add-on may or may not be executable/readable by all users.)
It is safest to follow Maysum Rashid's advice and install via the add-on installer on each machine.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
