ArchiCAD no wifi
Manta
Just a quick question
Am I able to use ArchiCAD with no wifi?
Like there is a competition for CAD Architecture and they do not allow any Wifi.
Would I have to download libraries like, shelves, chairs, bath, etc beforehand?
Thank you!
2 ACCEPTED SOLUTIONS
All of your default libraries are installed with the program.
It should work fine.
Just turn your wifi off and see.
mthd
A video giving information about library parts.
https://www.youtube.com/watch?v=OAmNXVzFmS0
Hope this helps ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
4 REPLIES 4
Thank You, It has worked well. One more Question, I there like an element library in ArchiCAD, like the Familes/compenent in Revit? I know that I can press on the arrow next to a window for example and then it brings me to the favorites. I am in the progress of taking the ArchiCAD course on the official website but when I do the same thing on the example that they give us. it gives me different kinds of favorites. As it is called "favorites" is there like a big library that I can view the elements, like different chairs, windows, furniture and etc...?
mthd
Hope this helps ?
Thank you so much!
this is exactly what I was looking for.
