Installation & update
ArchiTerra
I'm using ArchiTerra for the first time and having trouble getting it to do what I want; specifically the dxf import. I follow the instructions outlined in the documentation, it chugs along for a while, then I get lines and hotspots, but no 3D. Does this mean there is a problem with the dxf file or am I missing a critical step(s)?
1 REPLY 1
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
the hotspots contain info about the imported points 3D coordinates and the lines are the constraints between hotspots.
Now you have to define the terrain outline, using the ArchiTerra Outline tool and then you can buil the Terrain using the Terrain tool.
... but did you get the user manual too from your reseller?
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
