‎2025-02-05 01:55 AM
Archicad 28 is constantly freezing or crashing, diving a Direct3D / graphics card error.
Archicad 27 and Archicad 26 do not have the same problem.
I've updated graphics drivers, and uninstalled / reinstalled Archicad to no avail.
I get the same error every time; sometimes, it's within seconds of opening the program. Other times, it can take several minutes. But it happens multiple times a day.
'Direct3D Runtime received a Device Removed Message DXGI_ERROR_DEVICE_HUNG'
That's typically an issue with either the graphics card itself or the graphics card's connection the rest of the machine. However, this is the *only* program experiencing the problem, which is usually indicative of a glitch in the program or an incompatibility between the program and the graphics drivers.
These are two of the smallest projects I've ever done in Archicad, and the only two on 28 so far. Archicad 28 appears to be sending conflicting instructions to the GPU, which causes it to hang. No other programs are effected when it happens; in some instances, when it happens in one Archicad 28 file, it doesn't even impact the *other* Archicad 28 file I've got open.
Dell XPS 15 9530 with NVIDIA GeForce RTX 4060 Laptop GPU.
Archicad 28.0.2 (3110)
‎2025-03-05 03:16 PM
Check if You can disable possible built-in (discrete) graphics card. Sometimes they kill Archicad, if machine tries to switch adapter on the fly. Typically this happens when entering power save mode, connected to dock-station etc.
BR,
Ville
‎2025-03-05 04:59 PM
GPU Schedulimg is an acceleration process of Windows.
https://www.howtogeek.com/756935/how-to-enable-hardware-accelerated-gpu-scheduling-in-windows-11/
I sont know whether there is a conflict with it.
‎2025-03-06 10:57 AM - edited ‎2025-03-06 11:19 AM
No, we also have this issue on Desktop machines that don't have an iGPU but a dedicated RTX 3060 Ti.
This has IMHO nothing to do with Laptops or NVIDIA Optimus.
Since nobody else seems to have contacted Support, I opened up a ticket.
I got heavily criticized last time from support.
So just to clear out any confusion and offer transparency in advance:
- JamesMorris is not my real name.
- I work for a company I do not want to disclose here.
- I don't think support calls/mails are confidential. I will share information from that ticket with other forum members.
- Case number is: HTL00096209
‎2025-03-06 01:41 PM
I already opend two tickets with different energy saving options being turned off but both didn't help. We also don't have a GPU in the mainboard. I hope Graphisoft will release a hofix for this.
‎2025-03-06 02:21 PM - edited ‎2025-03-06 02:22 PM
I don't really understand why Graphisoft a hard time even acknowledging stuff like that. Why not be more transparent in your communication? Why not simply acknowledge such issues? Does not matter if by a status page, some well known issues page, or by an employee in the forums.
To me it seems like getting multiple tickets with the same issue is way more work.
‎2025-03-07 02:15 PM - edited ‎2025-03-07 02:36 PM
Hi everyone,
This was brought to our attention. We are in contact with the partner with the above-mentioned ticket number. And I'm here to clarify and help. As the error is with Direct3D and Graphics card related this could be due to different possible factors, I will break down a few things that could be checked before contacting support and some of these steps might solve the issue for some people:
Archicad side:
System settings/driver side:
Hardware side:
As mentioned this could be due to many factors, if you are still having problems after checking what is mentioned above, please contact your local support so we can investigate and help as this may be caused by different factors. We are always here to help!
Kind regards,
‎2025-03-08 11:02 AM
Hi @Batu Gezer, thank you for your answers and recognizing that there is an issue.
Despite the background model, these steps don't help or do not apply to us.
Local support reported back that they send this Budapest and that next time this happens I should send them:
- BUG-ID
- NFO of the machine. I assume they mean opening CMD and run msinfo32 /report C:\report.txt
- Fastlogger. For that you have to close all ArchiCAD applications and go to C:\Users\<username>\Graphisoft\Archicad Log Folder\<Archicad version>\FastLogger
‎2025-03-11 11:23 AM - edited ‎2025-03-11 11:23 AM
We were able to hunt down the issue a little bit more.
The user that is most affected noticed that it happens mostly at 13:30.
This is after his break. And what happens after his break? He turns back on his PC from Standby.
So we tried to reproduce the issue by simply having two ArchiCad 27 projects open and then go into standby. And it worked once. One of the two projects crashed. Second time we tried it, we were not able to reproduce it.
It also seems to be only happens when working in 2D.
As a side note, we have standby timer set to 24h, and we have hibernate disabled with Windows Group Policy rules. That is probably why we don't have this issue often, we only have standby if the user actively clicks it. If the issue really is standby related, you could not go into standby as a workaround.
‎2025-04-02 11:36 AM
We keep having the same problem even after the newest ArchiCAD Update.
‎2025-04-15 08:56 AM
We keep having the same problem even after the newest Hotfix.
