2026-03-16 10:03 PM - last edited on 2026-03-17 01:41 AM by Barry Kelly
In AC29 the menu has two pen settings that are duplicates of each other. I cannot see how to remove the unnecessary extra item. See attached screencaptures. Scott
Operating system used: Mac Apple Silicon 15.7.4
Solved! Go to Solution.
2026-03-17 01:40 AM
You also have two Partial Structure Displays.
Check the menu structure in your Work Environment.
I would be guessing you are using a custom WE possibly from an older version instead of a default 29 WE.
It should be easy to edit out the duplicates and re-save your custom WE.
2026-03-17 01:40 AM
2026-03-17 02:26 PM
Thank you Barry. I have been modifying the as supplied template WE but did not add those menu items. Scott
