Scott Bulmer
Archicad 29 bug - duplicate pen sets in Document menu
In AC29 the menu has two pen settings that are duplicates of each other.  I cannot see how to remove the unnecessary extra item.  See attached screencaptures.  Scott
Operating system used: Mac Apple Silicon 15.7.4
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
1 Solution
You also have two Partial Structure Displays.
Check the menu structure in your Work Environment.
I would be guessing you are using a custom WE possibly from an older version instead of a default 29 WE.
It should be easy to edit out the duplicates and re-save your custom WE.
Go to post
Scott Bulmer
Thank you Barry.  I have been modifying the as supplied template WE but did not add those menu items.  Scott
