mikkot5
Archicad on Mac not saving files
Hi, today I've run into this issue that Archicad won't let me save files. When I click save or save as nothing happens, the window doesn't pop up. I was saving files normally today both pln and pdf but suddenly it stopped working. I've tried restarting the PC and reinstalling the whole Archicad but the problem still exists. I have no idea what could cause this problem and how to fix it
If you have any ideas I'd love some help with this issue
2 Replies 2
arullan
I have no solution, but I have the same problem. AC 25 4013 on MacOS 12.0.1. M1 Mac. Hope somebody has a solution.
Minh Nguyen
Thank you very much for the report and I am very sorry about the experience!
As far as we know, it seems to be a problem with Monterey. A similar report on other programs can be found here: https://discussions.apple.com/thread/253309706
They suggest a secondary monitor is the problem here. Could you please let us know if this is the case?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
