I actually worked on this Interactive Training Guide.
First, to answer your question: normally, there is no need to explode the Drawing containing the DWG lines and fills. So that step could be skipped.
However, the reason it was done this way is so that it can be replicated by users. The cursor senses the nodes and edges of elements within a Drawing. But in that case I found (if my memory serves me right) it was not reliable for some reason. So I had to come up with a way so that it can be done.
This is an interesting aspect of creating training materials: you have to create them in a way that the users can re-create them from your instructions because you will have no chance to explain why something does not work, if that happens. So it has to be foolproof.
