BUG / R11 build 1114 / Attribute manager and lost Zones
Summary
ArchiCAD (1114) has for some reason started to delete my zone definitions! That's bad, but even worse is that Attribute manager has a bug which prevents me from importing them back.
In this screenshot the Open button (and the others buttons to) will do nothing / doesn't' work. (The others Tabs works)
(As you can see the hole dialog box is also corrupted.)
Description
... (se above)
Reproduce
No special steeps, just open Attribute manager ... happens again and again on my PC.
Workaround
Open the same file in version 970 and Zone attributes are back (just to disappear in version 1114 again)
ArchiCAD 11 INT (1033->1040->1086->1112->1114) Win XP sp2
Intel Core2 Quad 6700 / ATI Radeon HD 3870 / Dual LCD screens HP 30" + Dell 24" LCD
and
ArchiCAD 7+8+9+10 INT on Win XP sp2
3 Replies 3
Thomas Holm
You should report this to your reseller!
David Maudlin
HAlm:
See this topic:
Zones being deleted
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
So that is the source of the problem.
CadImage Tools again ...
They need to fix this now!
