Below Ground
Hi, how could i draw a structure that has a basement. Obviously, the ground floor isn't the datum level; and the building has to start from hte basement concrete slab up with teh remaning floors where the construction is of timber floors.
Brad Elliott
If I understand your question correctly open your story settings select your base story (different in the UK than here I think) and add a story below. Your base story keeps its datum and the lower story adjusts accordingly.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Thank you. Just tried it and it appears to work.. for now at least.
