‎2007-03-01 12:30 AM
‎2007-03-01 05:35 PM
John wrote:The Techjet Designer 720c driver is still supported in AC 10. I'm guessing your plotter has an old Parallel interface but it should work with a standard USB to parallel cable.
I need some advise on how to get my new iMac OSX 10.4.7 w/ ACad v10 to push my antique plotter. I'm an Apple newbie.
‎2007-03-01 05:56 PM
‎2007-03-01 06:30 PM
John wrote:I have an old HP designjet with a parallel port and that works perfectly with AC using the USB to Parallel cable. The mac just sees it as a USB port.
Phillip,
Thank you. I had been using my plotter successfully with ACad 10 on my old PC, but that computer was stolen! I need to figure out how to work it with the Mac.
‎2007-03-01 07:15 PM
‎2007-03-01 07:48 PM
John wrote:In plot setup there is a pull down menu that defaults to TCP/IP. Here you should be able to select USB as a connection.
I think I'm getting closer. In the plot dialog, it says, "Cannot Connect to TC/IP plotter"...
‎2007-03-01 07:55 PM
‎2007-03-01 08:13 PM
John wrote:
Yes, there are 4 choices: modem port, printer port, apple talk and TCP/IP. Unfortuneately it will only let me pick the TCP/IP. I'm still stuck, and I very much appreciate your assistance.
‎2007-03-02 02:52 PM
‎2007-03-02 02:56 PM
John wrote:ArchiCAD 10 standard installation includes the folder containing standard and OSX version
..where do I find plot flow?
