Defaults over multiple licences
I work in an office where we have 3 machines and 2 licences for ArchiCAD Solo. I would like to move the templates and work environment profiles so that they can be accessed from the central server. At the moment they are under the application folder (on Mac) so they can only be used by that computer.
1 Reply 1
In your Work Environment under 'Company Standards and Schemes > Special Folders' you can set the path to your template file.
Personally I don't use that system.
I just save my template as a PLN on a server that everyone has read only access to.
As for the Work Environment itself you can export that to a common location (server) and then import it onto any machine.
It is saved as part of your operating system user profile so as far as I know it can't be shared as such from a server but can be exported and imported when ever you need to update it.
