Installation & update
Does Archicad 16 work under MacOS 10.14 Mojave
MAKAA
Does anyone work or have knowledge if AC16 works under macOS10.14. I don't mean support - because I know that's not available, but whether technically AC will work?
Thank you for your information and support
5 REPLIES 5
Why not just try to install it and see for yourself?
First we ask? If someone already knows the answer to the question - because it works and someone is working that way, it will save me time (and time as some say is money ;>) to install and possibly uninstall the system.
It takes all of 5 minutes to install and start it.
You would have had it done by now.
I doubt many people here will still be using version 16 or MacOS 10.14.
mikas
AC16 FIN seems to run at least on 2017 intel iMac with Mojave 10.14.6 installed.
Me neither actually _use it_ but tested because I happened to have it installed in there.
AC28, Rhino8+Grasshopper, TwinMotion • Mac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
It works on mine mid 2014 MBP 13"Retina with Mojave 10.14.6 installed. ThankYou for conversation. Good luck!
