Dual Monitors
A Question on Dual monitor setup
On A MAC i just drag the 3D window Only to the other monitor EASY.
How can i do it on WIN XP with dual monitors, JUST the ONE Window if possible. Currently i can't do it without stretching (EXTENDING) the program window over both monitors.
12 Replies 12
I have been trying out different settings on Nview but have not found this facility. I would be really happy to use it because what you are saying make sense and would be preferable. Can you let meknow which Nview command achieves this? thanks for your input.
it would take too long to explain.
just do as i said in previous post and go through all of the nview options.
it could be that your gcard does not support this option though. not sure about that.
sorry i could not be more help.
thanks
I will first check out the card
