Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
Step-by-Step Tutorial [un]install
Due to space constraints on my C: drive I was forced to install ArchiCAD 8 in F:\Program Files\ArchiCAD 8
When I went to install the Step-By-Step tutorials I got distracted and accepted the default install location, which was on C: - I need to re-install it into F:
The tutorial does not have an uninstall program associated with it. If I simply delete the tutorial files from C: will I have Windows registry entries which need to be cleaned up before I can reinstall the tutorial into F: ??
Thanks.
2 REPLIES 2
Ben Odonnell
The step-by-step tutorials are html documents and ArchiCAD pln files only.
So by deleting the folders should do it for your.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Thank you for your help.
