2014-10-16 03:31 PM
2014-11-07 05:12 PM
2014-11-12 11:32 PM
Lennox wrote:If you are inclined, you could open your case and have a look to see how many amps your PSU can supply on the 12v rail, it should be on a sticker on the side of the PSU. Also, is it a double rail or single rail configuration? Eg. 24 amp on one rail is better for draw than 24 amp on two rails, as the 24 amp on two rails is split 50 / 50 at 12 amp each, which means if you're only using one power plug to your Gfx card you'll fall short if the requirement is above 12 amp.
Hi
Someone has mentioned that some graphics cards whilst not drawing over 450 watts, it would draw too may amps at a constant rate. Would this be the case with a GTX 750 Ti card?
Any suggestions?
