I need some help
Hi,i use ArchiCAD10 it works great,but when i change the view mode to 3D not working good,slow down
i dont understand maybe my computer is enough good?or what is the problem?
this my computer: Intel Celeron 2.4Ghz, 512MB RAM, Nvidia Geforce FX5200,
5 REPLIES 5
Dwight
3D views take time to generate.
There are two 3D methods depending on the result you need:
Internal engine - slower than OpenGL:
slowest with analytical shadows enabled.
best for hidden line views
OpenGL - faster than Internal:
but slows down if you ask for fancy options like textures.
speeds up with a smaller rendering radius - see "options" in 3D View dialog box
Try reducing options to speed up the render.
Dwight Atkinson
It probably is the computer. The Celeron is a crippled version of the Pentium and you are also a light on RAM.
Dwight
What would the minimum RAM be?
Dwight Atkinson
GS wrote:
1 GB of RAM is required
2 GB or more is recommended for complex models
Paul King
Mentor
Switching from 1 GB to 4 GB made a lot of difference for me for speed of opening & editing the very same model.
At 1 GB, most memory is absorbed by operating system & any other apps running, So ArchiCAD needs to keep writing & reading from hard drive instead ( "page faulting") - which is obviously many times slower.
Hate to think how bad it would be on 512mb!
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
