Java issues
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-02-11
08:29 AM
2024-03-27
03:26 PM
Aruzhan Ilaikova
2014-02-11
08:29 AM
I was given a copy of Archicad 17 to roll out, but noticed it needs java 17. Java 17 causes issues with our oracle forms so we are stuck on 16. What would break if I remove 17?
Thanks
Stuart.
Thanks
Stuart.
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-02-11 10:50 AM
2014-02-11
10:50 AM
Hi Stuart,
Looking on the Graphisoft website I see that both Java 6 & 7 can be installed at the same time.
In fact we need to have both as we use WIBU keys for our licenses.
Here is a quotefrom the Graphisoft website ... http://www.graphisoft.com/downloads/java.html
If both 6 and 7 are installed can Oracle Forms automatically use Java 6?
It seems the different Archicads can choose which Java they need so just wondering if Oracle Forms can as well.
You can always test it on my machine
I have 17 installed but have no need for these oracle forms so I wouldn't have noticed any problems.
By the way isn't Java distributed by Oracle?
Shouldn't they update their software? - or is that too much drama in an office the size of ours.
Here's a quote from the Java website.
Whether it will have problems I don't know as I haven't fully tested it.
But I think when there are updates or the next version 18 then Java 7 will get re-installed.
Now that J7 has been removed (I still have J6) this forum and the Internet Explorer seem very slow.
Coincidence?
I haven't restarted my machine so I might try that in a minute.
About Java 7
ArchiCAD 17
If you installed ArchiCAD 17 with Wibu protection you might need to install Java 6 separately in order to run ArchiCAD with your key. WkConfig requires Java 6, so if it is not present on your computer use Java 6u32 installer from the above list.
ArchiCAD 16 Hotfixes
If you are installing an ArchiCAD 16 Hotfix on Windows platform, Java 6 will be required even if Java version 7 has been already installed on your computer. If Java 6 is not present on your Windows you can download and install from the links above. The two Java versions will not interfere.
Do I need older versions of Java?Just as an experiment I just removed Java 7 from my laptop and Archicad 17 still opens.
The latest available version is compatible with the older versions. However, some Java applications (or applets) can indicate that they are dependent on a particular version, and may not run if you do not have that version installed. If an application or web page you access requires an older version of Java, you should report this to the provider/developer and request that they update the application to be compatible with all Java versions.
Coincidence?
