DiogoFernandes248
Keyboard Shortcuts
Hello, I am having a strange problem with Archicad23. I am able to use the keyboard to do some shortcuts such as Cmd E and Cmd D but then I am not able to use ''L'' to draw a line and I am not also able to use Cmd 8 and Cmd 9. Do you know how I can change this ?
Thank you all!
1 Solution
You set the shortcuts up in the Work Environment.
If those shortcuts aren't assigned, that is why they don't work.
If they are assigned and they are not working, then maybe some other program in your operating system is hi-jacking the shortcuts.
Go to post
2 Replies 2
DiogoFernandes248
Thank you very much, it was exactly that. I hadn't applied my regular work environment but then when I did it everything worked 🙂
