Fereshteh Sardari
Language
Hello everyone,
I have downloaded the Archicad 28 English version and installed it, but the language of the program is completely in Italian, do you how I can change the language to English?
1 Solution
Are you sure you didn't install the Italian version?
It is a separate install for each language.
If you go to the HELP menu > About Archicad (or what ever that may be in Italian), what language does it show?
Go to post
5 Replies 5
CosminF
Can you maybe take a look in this thread? https://community.graphisoft.com/t5/Installation-update/Language-changing/td-p/573927
I assume AC28 UI language is in the same scenario.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Fereshteh Sardari
Yes, I had been installed the Italian version unfortunately, so I uninstalled it and did it again with the English version. thank you for your answer by the way.
Fereshteh Sardari
Thank you for your response, but I had to uninstall and do it again with the English version.
You can install both versions if you need them.
Just give them different installation folders when you install them.
Or install one  and re-name the folder and then install the other.
You just need to make sure which version you are running.
I don't have different languages loaded, but I do have different build numbers.
