Morphs disappear with marquee tool
I have just recently updated my ArchiCAD 20 to the 6005 build update and I have found that when using the marquee tool to show selection in 3d, all the morphs disappear. Though I can view morph boxes or morph objects revolved, just no non-solid morph 'planes'.They are still there in 2d but are not visible in 3d.
If I view in 3d with 'show all' (same layer settings) they re-appear.
if I view in 3d with 'show all' in 3d and use the 3D cutaway tool they appear as well. (again, same layer settings)
Does anyone know what could be causing this? A bug? Some new default setting I'm not aware of?
Thanks,
Dave
2 Replies 2
Katalin Borszeki
Hi, we could not reproduce this issue on AC20 INT, nor on the AC20 USA 6005 build. Could you send us a file in a PM? best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
ksjhawk
Did anyone figure this out. I have the same issue with morph planes and lines. Using AC22 on a mac.
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
