My Archicad12 do not show a "Tool tips" ?
Archicad12+Window Vista
Only tool tips shown for Standard Toolbar.
But for the Tool box and Status bar,there is no tool tips show (only tiny rectangular box show under cursor).
How to set?
12 Replies 12
Same problem here. Also having flickering issues/ fills not showing up unless I zoom way in. AC 13 64 bit
Brett Brown
I had the same problem and the cause was having the text size in Windows set at 125%. Setting it back to 100%, tool tips appear. I asked Graphisoft if this is fixable in Archicad. Will post reply
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Better late than never ... nearly a week on this exasperating problem and nobody to bring help anywhere.
Brett, YOU REALLY ROCK ... big up for you !!!
Setting the text size in Windows back to 100% is the solution (on a Win7 64 bit + Archicad13 64 bit plateform)
