Render Problem...
i am very very sorry, i dont speak english...
i am using ArchiCad 9,
My Project Render (F9), everything ok. 3D (f10)after few minutes error: LightWorks Rendering Engine.
But part of project 3d, everythings ok.
Please Help Me.
My PC configuration:
P4 3.2Ghz 2 MB Cache
Intel 945GNT MainBoard
4 GB DDR 667 Memory (HI-LEVEL)
PALIT 256MB/DDR3 GF6600 GT
200 GB Sata Seagate
Dwight
This problem is probably because of a bad object in your model or a model that is too large for the computer memory.
-- The bad object must be removed - it will have errors or bad parameters.
The best way to locate the bad object is to make renderings with different layers turned off until finding the layer with the bad object.
Change the bad object.
-- Some models with too many polygons cannot be rendered. Especially Spanish tile roofs or lots of spheres.
Reduce the number of parts in the model and experiment to see if the rendering works.
Dwight Atkinson
