mouse problem
hi
there is a problem with my mouse. i can not pan with the wheel. i reinstalled the driver, even reinstalled ArchiCAD ,no use. i changed my mouse but i can not pan again. can anybody help me?
4 Replies 4
If this is a microsoft mouse and you're using the intellipoint driver do the following:
With ArchiCAD running go to Start->Control Panel->Mouse. Go to the Wheel tab (I think) and click the Troubleshoot(er) button. It will ask you to identify the program with the problem. Select ArchiCAD from the list of running programs and continue the troubleshooter. Once finished this should fix the problem. You'll need to repeat the same process with PlotMaker.
hi
thanks for the reply, but it did not solve the problem. any other sugestion.
In a Mouse properties check if you are using proper mouse drivers. Maybe the mouse button assignment is not proper ? It should be assigned as a "Middle Button".
i had the same problem with a Raptor Gaming
its a problem in the driver
it doesn't provide a "pass-through" function for the wheel button
the only solution in di uninstall or disable manufactirer driver an use the windows driver
