Installation & update
SciTech GLDirect 4 Demo
SciTech GLDirect 4.0 it is a shareware hwo
can convert archicad opengl capability in directx DirectX 7, DirectX 8, and DirectX 9.
verry useful for opengl problems
4 REPLIES 4
Nice !
Though it would have been nicer to know that somebody had courage and tried it out. (If I learnt anything in the past few years about IT, well, that would be: Don't fix it if it's not broken. )
Here's the link for more adventurous types.
Paul King
Mentor
What is that link? Your post seems to have been "pruned"
Cheers
Paul King
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
stefan
Check google šŸ˜‰
http://www.scitechsoft.com/products/ent/gld_home.php
Archicad-user since 1998
my Archicad Book
Paul King
Mentor
While I don't have any Open GL problems (I have an ATI Radeon 9700) I was curious & tested the GLDirect4 using emulation via T&L Hardware aceleration and DirectX9 - the most "accelerated" settings for DirectX that my card can use (or any current directX capable card for that matter)
Using a fairly complex test model, I discovered the result indeed works, but is VERY much slower and chews up a lot more RAM.
On an older card, I imagine this emulation performance would be even worse.
Based on that, I think if you have OpenGL problems with your current card, you are better off simply coughing up for at least a high end "gaming" card like Ati Radeon 9700 or 9800 Pro, or Nvidia FX 5800 or FX5900 - which all handle OpenGL very well.
Would be interested to hear others experiance?
