Scroll Wheel
When I start AC11 the scroll whell on my mouse acts a vertical scroll control.
After doing some work and various mouse clicks, the scroll wheel becomes a zoom control.
I have not been able to find out exactly what changes the function of the
scroll wheel?
Does anyone have a similar problem? Whats the answer?
Thanks
4 REPLIES 4
Just press Control while scrolling.
Have same problem on several computers while zooming with wheel (archiCad version 11).
Pressing "control" while using zoom on wheel doesn't help, it still moves vertically up or down.
Does anyone have the anwser ?
Thank you
Check the settings of the mouse through the OS. Also, if you're using a logitech, i believe that there are some compatibility issues with the 'Set Point' driver software.
Tried with and without mouse drivers, tried different settings for mouse and wheel.... Still same vertical moving
