2004-04-01 11:43 PM
 ); .PLP's are accessible only from the computer that they were created on originally.  If I try to sign into one from another computer, AC brings up a blank screen as it would when starting a new project with the title "untitled."  Help?
); .PLP's are accessible only from the computer that they were created on originally.  If I try to sign into one from another computer, AC brings up a blank screen as it would when starting a new project with the title "untitled."  Help?2004-10-06 07:47 PM
2004-10-07 10:34 AM
2004-10-07 06:26 PM
Lasse wrote:I used to use satellites, but their behavior has been erratic over the years, so I have never found a way to standardize their use. In 8.0 they were a nightmare the one time I tried them, and I didn't bother investigating any further.
I've never tried satellite libraries as I think it's to complicated to explain and manage for 30 users.
Am I wrong?
2004-10-07 06:59 PM
2004-10-07 07:00 PM
2004-10-07 11:50 PM
Ted wrote:I never quite understood the satellite library concept either. We have 9 users and I can tell you that making sure all of your hard drives and folders on the path to your local libraries will help. We were having problems with the background archicad dropping library parts that seems to be fixed with keeping the path the same on all machines.
I would consider setting all of hard drive names the same if could simplify the users' experience (we are 13).
2004-10-08 07:27 PM
Millard wrote:We had the same problem with BGArchiCAD, but it seems to have gone away with the setup of multiple OOB libraries on teamwork files (as described in my previous post). single user .pln files would still have the problem if not opened and saved by the same machine using the lbk.Ted wrote:I never quite understood the satellite library concept either. We have 9 users and I can tell you that making sure all of your hard drives and folders on the path to your local libraries will help. We were having problems with the background archicad dropping library parts that seems to be fixed with keeping the path the same on all machines.
2004-10-08 07:52 PM
2004-10-08 11:34 PM
Ted wrote:I've used it for years, as have many of my clients, with no problems. The only thing I don't like is backing up to tape. CD/DVD and hard drive backups are best.
(off topic + reality check)
Retrospect for backups?
2006-03-21 09:04 AM
