Trial version Archicad 13 - Quick Time error on startup
Trial version Archicad 13 - Quick Time error on start-up
I cannot fix this problem as per the advice in this forum as I do not have a installation dvd...so do not have the support folders indicated to correct this problem.
I have reinstalled Qucik Time 7 twice and rebooted the computer after....do not have an option to install 'recommended' when downloading.
I hope it does not mean that I have to buy Quicktime.
Would appreciate any help and advice on how to rectify this problem so that I can see what all the fuss about Archicad is about.
I currently use AutoCAD for technical drawing but have a client who wants 3d drawings which is impossible on AutoCAD.
12 Replies 12
same problem on my windows 7 - 64bit system (hp laptop). I have tried the three installs listed below in the support folder. Still archicad 14 will not open....help - anyone? I've called tech support about 10 times? btw runs fine on windows vista desktop
The same problem here with no solve. I tried all the tree solutions. I have Windows 7 , archicad 14 student 64 version.
Solution no 2 provided by Gorazd worked for me:
I've deleted the content of "Program Files\Common Files\Graphisoft Shared" folder and ArchiCAD v14 started.
There was no need to install anything extra from DVD.
