We value your input!
Installation & update
Trouble upgrading the WIBU!
Hey Graphisoft (and AC9 users):
The Serial Number you gave me on the "Keyplug Remote Programming PIN letter isn't working on the https://upgrade.graphisoft.com/ website.
I contacted my re-seller, who gave me an e-mail address (ac9install@graphisoft.com) that rejected my e-mail.
Anyone else out there having problems?
Thanks,
GK
1 REPLY 1
David Tauer
Graphisoft Alumni
Graphisoft Alumni
Hi Eugene,
The correct email address is : v9install@graphisoft.com.
If you're getting an 'Upgrade Not Authorized' message, this means that the pin# has not yet been attached to the key.
What I would need from you in this case is your Serial#(s) (the number on the outside of your Pin Letter) that you are having problems with. i will then check with Order Admin and verify/have your pin# attached.
I'm sorry for the inconvenience.
With Best Regards,
Dave
David W. Tauer
Graphisoft U.S., Inc. - Boston
1-800-238-3992
http://www.archicadwiki.com
