WIBU Key problem
My harddrive corrupted, so I reinstalled ArchiCAD 10 after getting a new drive, but it keeps on stating that my WIBU-Key cannot be found, even though the pc found it and installed it as hardware. Please advise.
Thank you,
3 Replies 3
Contact your reseller. It may be that you will need to re-register the key online.
or you need to install your WIBU key using the driver provided by Archicad within the CD ("if the incorrect driver is asigned, then the key will not respond correctly")
Thanks for that, Jean-Luc and Phillip; I've already sent an email to my reseller, and will advise how it comes out.
Be well.
