‎2003-12-08 07:32 PM
‎2003-12-10 11:33 PM
‎2003-12-11 12:03 AM
Rob wrote:You are right, is PlotFlow (but I call PlotSpool because is the name of my Spool Folder, sorry if I have confused you)
Miguel, thank you. What is Plotspool? Is it a utility supplied with ArchiCAD? Is it PlotFlow, the plotting utility supplied with ArchiCAD
‎2003-12-11 04:27 PM
Rob wrote:It's a fair possibility. It would be worth your time to try and get the 220 plotting using the same methods as getting a HP 500 running.
Thanks JC, I've reviewed all of your info links. With my current designjet 220 and an jetdirect external printserver box like the 300x you refer to, do you believe I'd be able to successfully plot? Or do you think the designjet 220 is too old for this kind of trick.....I understand I'd need to configure the IP/port addresses of the jetdirect box.
‎2003-12-11 08:16 PM
‎2003-12-11 09:36 PM
Rob wrote:rob,
‎2003-12-11 10:01 PM
‎2003-12-12 12:56 AM
‎2003-12-12 04:07 AM
‎2003-12-12 11:59 AM
Rob wrote:jetdirect 300x
Very interesting Ben, what model jetdirect box are you using? I'm thinking I might be able to address the jetdirect box through the UNIX foundation of OSX.....
‎2003-12-12 02:32 PM
