Installation & update
Wibu or code meter key status
Did anyone know that you can't use your wibu or code meter key to work on different version Archicad 18. If i use archicad 18 US and want to use Archicad 18 French it doesn't work anymore.
Why
1 REPLY 1
This seems odd when we are supposed to be able to teamwork with anyone from around the world.
I have just started 18 AUS and 18 INT at the same time using the same local WIBU key.
Both version are the original build 3006 and haven't been updated.
I started a third one (18 AUS build 4020) and they all seem to be running happily together.
I just don't have the latest hotfix (build 5100) installed - seems to be a few issues with it at the moment.
What builds are you running?
