Antpel
archicad 26 crashes on start up
SO i download and install archicad 26 it works for a day or so then it wont start work when i go to use a few days later unless i download it again. anyone else have this issues there is a bug report that goes to graphisoft but i never hear back from them. I am running a computer with windows 10 64bit its about 4 years old is it the computer or software ??
1 Reply 1
You won't hear from Graphisoft.
Take note of the bug report number and contact your local Archicad support and ask them to investigate it.
Could it be that your anti-virus software is quarantining something from the Archicad program folder?
If your anti-virus is set to scan only at certain times, it may allow you to run for a little while and then quarantine a file required by Archicad.
You should be able to see in your quarantine logs if that is the case.
