2009-12-18 02:09 PM
2009-12-19 09:33 AM
stefibe wrote:Cannot comment on Airport, but very happy with the 110+ and since
/...... give us his experience and impression of use of this
plotter HP 110 plus with archicad...
Also i like to know if Airport Extreme con connect hp 110 plus with usb port.
2009-12-22 05:20 PM
2010-01-10 10:41 AM
Rod wrote:grazie..!!stefibe wrote:Cannot comment on Airport, but very happy with the 110+ and since
hotfix 2 fixed printing issues for 13
2010-01-10 10:45 AM
inpro wrote:yes i will think about a roll
Personally I do not recommend you buying it. It is cheap but since I bought it 3 years ago I am continuing to curse its plastic mechanics and paper handling. But if you take this one you will absolutely need a roll feed for it.
2010-01-10 12:44 PM
stefibe wrote:Stefano, I print via USB and the quality is as good as the paper you use.
/...your hp 110 has network port or you use usb port..?
archicad command you use is prin or plot..?
2010-01-26 06:08 AM
2010-02-16 11:25 AM
2010-05-25 02:20 PM
2011-01-13 08:23 PM
nestorovski wrote:did you ever solve your print margin troubles?
Does anyone has ever used hp designjet 510 42"? i have some problems with the printer margins... Thank you
