Installation & update
hp 4500ps Problems with plotmaker
Is it possible to add the hp 4500ps to the list of supported plotters in plotmaker?
6 REPLIES 6
"YLH",
Yes it is possible to add other plotter drivers.
Franky,
do you happen to know what that process might be?
"YLH",
Have you tried installing the driver from the CD you received with your HP 4500ps plotter? If so, after you install the driver you should import it into plotmaker.
Cheers mate,
Frank
Franky,
I did not know it was possible to import a driver into plotmaker... the driver has been installed on the computer, do you mind letting me know how i would go about importing it into plotmaker?
thanks
Rafal SLEK
When You install your driver it automatically will be shown on your printer list in PlotMaker. You do nothing (no import is needed).
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Rafal and YLH,
It is true that when you install your driver it will show up on your printer list in PlotMaker but usually when you print from plotmaker you loose a lot of quality and fill types/composites come through incorrect. That is why it is better to plot then to print.
My suggestion after reviewing my own PlotMaker would be to create PLTs (plot maker files that can be created in plotmaker) and plot them through "Plotflow".
Hope this helps,
Franky
