on
2025-09-10
11:01 AM
- edited on
2026-09-25
02:29 PM
by
Benjamin Dani
Apple released macOS 26 Tahoe on September 15, 2025. We are thoroughly testing it to ensure compatibility with our products. Based on our current tests, Archicad operates with the issues listed below.
We are not aware of any critical issues.
We will update this article with the latest news while testing macOS 26 Tahoe.
Affected version(s): Archicad 29
Issue
The AI Assistant button appears outside of the main Archicad window when the Archicad window is resized on macOS Tahoe.
Workaround
No workaround.
Solution
The issue is still under investigation. We’ll keep you posted as we learn more.
Affected version(s): all Archicad versions | ID: DEF-22356
Issue
When attempting to render an image with Cineware or change the Surface Settings for the Cineware engine, it returns an error: "Cineware by Maxon add-on has unexpectedly closed.". This issue was first found in macOS 15 Sequoia.
Workaround
Restart your device. If it does not help, replace the Cineware folder (/Applications/Graphisoft/<Archicad version>/Cineware) with the working one.
Solution
The fix for this issue is available in Archicad 29.1.0. Please update your Archicad to the latest update.
We’re also looking into backporting it to earlier supported versions, but this isn’t confirmed yet. In the meantime, please use the suggested workaround if you are using an earlier Archicad version and contact support if the issue persists. We’ll keep you posted as we learn more.
Affected version(s): Archicad 27 and earlier versions
Issue
Chevrons are not centered in parts of the Archicad interface.
Workaround
No workaround.
Solution
The issue is fixed in Archicad 28.
Issue
If the relevant option is chosen in System Settings > Desktop & Dock, the Archicad workspace may not resize to fill after double-clicking on the window title bar. The rest of the window may stay grey.
Workaround
Use the default Zoom option or update the Work Environment in any way (choose any Work Environment profile or resize any palettes, toolbars, etc.).
Solution
Issue
Depending on whether the Archicad window was smaller or larger before docking, a part of its window may become grey and unresponsive when docked or dragged after docking.
Workaround
Update the Work Environment in any way (choose any Work Environment profile or resize any palettes, toolbars, etc.).
Solution
While we are still in the active phase of testing BIMcloud, we are not aware of any critical issues so far.
Please note that there is a new security feature (introduced on Sequoia) that blocks network searching. Make sure to authorize Archicad on the local network to access BIMcloud from Archicad.
Go to System Settings > Privacy & Security > Local Network and enable this setting for all Archicad versions.
We are not aware of any issues in BIMx Desktop 2025.6760 or newer.
Should you decide to upgrade, please follow the upgrade checklist below.
