repair installation ac 17
i just had to do a repair of ac 17 and i selected "back-up and repair" so now i'm wondering, where is my work environment and favourites?
wb
9 REPLIES 9
David Maudlin
wildernessbob:
For your Work Environment, open the Work Environment, click the Import... button, then try searching at: /Users/[user name]/Library/Preferences. You can search more broadly, but the search takes more time.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX11.7.10
What exactly am i searching for? is it called "work environment" or is there a folder? what was the backup that ac did before the repair? would it be there?
wb
vistasp
Wiki article on where AC stores Work Environments:
http://www.archicadwiki.com/PreferencesCleaning
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-26 INT | Win10 | Ryzen 5700 | 32 GB | RTX 3050 |
I can't say whether Archicad would have backed up your work environment with the 'Backup & Restore' option as I have never tried it.
But I always make a habit of 'Exporting' my work environment to a know location so I can 'Import' it at any time in the future or even use it on other machines.
As for your favourites they are stored internally in the PLN so they should still all be there when you open the file (same with model view Options).
You can save your favourites out so you can load them back in to another file as well though and I find it is a good idea to do this if you want a standard set of favourites across all your jobs.
Versions 6.5 to 26
According to this Archicadwiki article ...
http://www.archicadwiki.com/Repair%20ArchiCAD
there should be a "Backup" folder created in your Archicad folder.
Versions 6.5 to 26
thanks vistasp, but those folders don't exist in OS 10.8, thanks too Barry, but it doesn't really help me here. i did the repair but can't find my work environment. i'm going right to the horses mouth and call tech support. i'll let you know what happens.
wb
vistasp
Hmmm... Looks like the wiki might need an update.
= v i s t a s p =
bT Square Peg
yep, me thinks so. but, mine was of course, not straight forward. i actually had to go into the time machine and restore a folder, and i'm sorry, but i can't remember which. tech support had to get me there. the moral of the story is, export a copy of your work environment to some other place on your HD so you have it when you need it.
wb
vistasp
Call me paranoid but my data and settings are backed up daily to another PC on the network, a NAS device and the cloud (Mozy Backup).
= v i s t a s p =
bT Square Peg
