10ml glass door in bathroom
As the above says my boss has specified a 10ml glass door which I am trying to put into the plan. no door will go to 10ml thick, I tried making my own door and it only came up as a empty space. I need it to be 600ml wide and to sit next to a glass panel also 10ml but only 180 wide. what would be the best way to go around this? thank you
Just use a 10mm thick wall set to the heights you want (wasn't this mentioned in another post just a few hours ago?).
Just because it is a door doesn't mean you have to use a door object.
Or find a shower screen object in your library (not sure what libraries you have).
australian essentials library part "swinging door" goes down to 1mm thick
