2 identical houses but mirrored
Too Long
I have a job with two identical house that are side by side and mirrored to each other.
If a draw the left one to completion, can I make a copy for the right one so that all the views are mirrored too so that I dont have to draw them twice?
Ive noticed that any 2d elements in elevations dont mirror unless im doing something wrong.
AC26 AUS Full
If you are manually reversing a model, then you must also mirror all of the 2D info in sections and elevations as well as this doesn't happen automatically.
Having said that, I am pretty sure Central Innovation have (had?) an add-on that can reverse everything including the section and elevation 2D annotation.
If you have a Select Agreement with them, I am sure you can get some 'free' add-ons.
I am not sure if this is one that is included free or not.
Might be worth looking into.
But if it is just the one plan, I would just save it as a new file, mirror it and fix up the sections and elevations.
Yep, thought so mate, thanks
AC26 AUS Full
If they are exactly the same, another options is to save it as a module, and then insert it. You can mirror modules, but you would have to document them independently.
