2D Fill overlap? Help?
JGoode
In the top part of the image you can see with FILL "EMPTY FILL", it is transparent but as soon as it is replaced with anything else then the second part of the image happens. The red symbol is written in the script before the fill is. The bottom image is the red symbol code. How can I move the fill behind the red symbol?
Thanks
ArchiCAD 23
Windows 10
sinceV6
Hi.
You can either use DRAWINDEX or change the order in which things are scripted (i.e. bottom fill first)
Best regards.
Or is it just a case that your 'back_FILL' parameter is not set to the transparent (0) pen?
JGoode
I have solved it now. DRAWINDEX worked nicely, thanks.
ArchiCAD 23
Windows 10
