2d Object No Rotation
I would like this 2D symbol to look the exact same regardless of how it is rotated or mirrored . I'm not sure exactly where to put the rot2 -symb_rotangle command.
iMac (Retina 5K, 27-inch, Late 2015)
Sierra Version 10.12.6
ArchiCAD 5021
1 REPLY 1
Right before the lines that create the part of the object you don't want to un-rotate.
So in this case just before the LINE@ and RICHTEXT command.
But you will probably want it after the MUL2 and ADD2 commands as you will probably still want to perform those transformations before you un-rotate the object.
