ā2009-07-23 12:50 AM
ā2009-08-25 09:37 PM
Braza wrote:Could you explain?
Finally repeat the same procedure to restore the original subtype.
HTH
ā2009-08-25 10:34 PM
ā2009-08-26 11:14 AM
Erika wrote:Thanks Erika... That's it Joseph.
Joseph,
Paulo instructed you to redefine the subtype of the library. After reloading the library so the object now has this new subtype you then open it up and change the subtype back to what you what it was.
The difference is it now has it's own new internal number so it will not read as a duplicate of the AC library object.
HTH
ā2009-09-01 11:59 PM
