Streamline your workflows and master BIM coordination! Program starts April 28.!
A problem!
Can anybody explane me how to add objects in library? I downloaded many of them from the internet, and next to each it wrote arhicad object, but when i am trying to add them it arhicad says only gdl object?!!
5 REPLIES 5
Erich
Jasna,
What type of object did you download? In order to be read directly by ArchiCAD the objects must be a .gsm. If you have something else (i.e. a .skp or a .obj, etc.) then it might be able to be converted to a .gsm to be used by archicad.
If the objects are the correct type already, then place them in a folder/directory. Open archicad and load that folder/directory into the project via the library manager.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Its downloaded directly from graphisoft, i dont know what type it is, it only write -arhicad object for all of them. And now i dont know to add them. you mean i can put them in specific folder and then add them?
its working, thank you!
it still wont do it propertly!
Erich
OK, so what it is doing now - or not doing? We need more information in order to help.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
