‎2006-06-01
02:18 AM
‎2023-05-26
11:39 AM
Rubia Torres
‎2006-06-01 03:41 AM
‎2006-06-01 04:45 AM
‎2006-06-01 05:58 AM
‎2006-06-01 02:05 PM
‎2006-06-01 02:47 PM
‎2006-06-01 03:38 PM
Link wrote:I would encourage you to open your blank template file and make favorites of anything and everything. In 10 only the favorites for that tool are displayed in the fav window. This really helps plowing through them.. shortens the list a lot. I use to keep my template file open on another screen just to copy paste settings. Now I don't need to. Another advantage is working on an older file. It is easy to upgrade that file with your newer settings.
, or even better make a favorite of it!
Link.
‎2006-06-02 12:01 AM
Link wrote:I do not own a copy of AC10 yet so I can not try this, but I was under the understanding that objects from the Standard AC 9 Library can not transfer parameters to the new AC 10 Library. This was the case with attempting to transfer parameters from AC 9 (Standard) to AC 9SE library. And I thought that the AC 10 Library was based on the AC 9SE.
I haven't tried this in AC10 yet, but you should be able to eye-drop the parameters from your cool AC9 door, then open the Door Settings dialog, and inject thepreview iconof the corresponding AC10 door, *before* you click on it. Then you can either insert a new AC10 door, inject it back into your original AC9 door, or even better make a favorite of it!
‎2006-06-02 04:05 AM
Jay wrote:I was meeting with a client today (also a beta tester) who told me that he had opened a project in 10 using only the AC10 library which was started in 9 with the SE library. Not only did it open with no problems (or missing parts), it also saved back to 9 (and SE lib) without incident. This is despite a name change for the parts. It looks like we really need to get to know how this GUID stuff works. This experience suggests that it could turn out to be a very good thing. (I'm still troubled by the impenetrability of the codes though.)Link wrote:I do not own a copy of AC10 yet so I can not try this, but I was under the understanding that objects from the Standard AC 9 Library can not transfer parameters to the new AC 10 Library. This was the case with attempting to transfer parameters from AC 9 (Standard) to AC 9SE library. And I thought that the AC 10 Library was based on the AC 9SE.
I spent many wasted hours attempting to get the AC9SE library doors and windows to work as I liked. I went back to Standard Library.
