AC 12 Add-ons
Im a network Administrator, and im supporting a company that works with ArchiCAD, and one of them is having the problem bellow, when he tries to access the program.
Can you please explain to me what is happening
Problem: ArchiCAD could not be launched because the following add-ons are
missing:
Interactive Schedule
In order for ArchiCAD to start, these add-ons must be placed in this folder:
C:\Program Files\Graphisoft\ArchiCAD 12\Add-Ons
David Larrew
The "Interactive Schedule.apx" Add-On file should be stored in the "Add-Ons" folder as the message describes. This Add-On should be located in the "Standard" sub-folder of the "Add-Ons" folder.
You may need to re-install the ArchiCAD application, this should fix the issue.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Thank you for you quick answer, ill try that and post back the result.
