AC Version & Library Transition
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2003-11-17 07:39 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-17 09:54 PM
I am in a similiar position, just started on 8.1 and opened a project from 8.0.3
Here is what I did:
Save the old project as "Archive" pla - give it a slightly changed name so that you still have the old file intact.
Start AC 8.1 while holding "Command (Apple) - Option keys, this will open the Special menu.
Select the previously saved file and open it.
In the Special menu select "Update Library parts" and let the program upgrade them.
Then check your Library Manager for missing/duplicate libraries and load/remove them.
Don't forget to load the 8.1 library folder from the recently installed update. You will not have all the parts that you may want to use in the future.
HTH
Jacek
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-18 12:14 AM
I did such thing with a project started on 8.0r2.
It worked on INT libs both 8.0 and 8.1
Most of the parts in those libs are named the same...so I use the new parts from the "switching point"
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-19 01:22 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-19 01:58 AM
Dave wrote:Dave,
Maybe if I had had many different types of objects placed in 8v3 the results would have been different. I haven't checked the libraries to see how many names have changed. If I remember correctly (very possible I don't), library objects changed names often in past upgrades. No?
I had a project with a little over 800 parts, plus textures, etc.,
and dating back to 6.5!
Following the procedure that I have described I had only 20 or so duplicates, all textures that were not culled from the previous file, and just 'came along for the ride' in the previous version. With 20 or so library parts it is probably worth to just replace them with new ones. Just so that they will not come back to haunt you later...
Jacek
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-20 03:33 PM
Dave wrote:Since AC 8 was introduced the priority for the program when searching for lib. parts is (in chron. order below):
Piotr's method worked fine--all doors and windows came up in 8.1 exactly like 8v3. I thought the 8.1 library folder naming conventions would screw things up, but the objects themselves all have identical names as the originals in 8v3..... If I remember correctly (very possible I don't), library objects changed names often in past upgrades. No?
1) by the GUID number and Revision ID number given to the lib. part
2) by the GUID number of lib. part
3) by the name of the lib. part
this step (I believe) was taken to get around the duplicate library parts syndrome if some lib. parts had the same name set to them, or if a library part got a somewhat different name to it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-20 05:44 PM
At the beginning of my relation with ArchiCAD after listening to the sales pitch of the GS salesman I have asked this question:
Jus for long this library parts will remain compatible with the program.
The answer was : As long as there will be ArchiCAD. I called GS and was reassured of this as a fact,
And this is the way it was version after version. Since many of us modified library parts and the new version just whipped them out we had a common wish; Name the folder with the version number.
Using this as a subterfuge GS started to name each object with the version number and through “agents” let us understand that there area compatibility/speed problems with the old ones. This is inadmissible and counterproductive to the dream of GDL being embraced by the industry,
_________________
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-20 07:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-21 09:37 PM
GUID's: Opening ArchiCAD 7.0 or AC 8 files with ArchiCAD 8.1
posted in FAQ's Rec# 671
http://tr.graphisoftus.com/
Regards.
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2003-11-26 12:04 AM
Jacek wrote:Having used this feature on a number of occasions I have yet to see that it does anything to specific objects (like updating scripts, names, etc.) loaded in your libraries, so I have come to the conclusion that this feature is intended to update libraries located on an FTP server. Can anyone at GS provide some insight to intended function of this feature?
HTH
Jacek
TIA
