AC15 RoofMaker: No library-parts
Any help appreciated
In AC15 when trying to use the RoofMaker, it says the part is not found in any library
That makes perfect sense.
So where is the library of parts located for the RoofMaker tool?
Thanks
Oneway
4 REPLIES 4
They are part of the standard Archicad library.
My library and object manager does not look like that
If I start a new project with the default template, and when I open the Manager I see a folder called ArchiCAD Library 15 in the linked category, but it does not allow me to open the folder.
Further the manager does not have the combo box yours does (Folder View) and instead has a button that says Add... and an extension button with an arrow pointing right. Clicking the button brings up the system open file dialog with a boat load of extension in the filter set.
Clicking the arrow pops up a context giving three choices to either browse, link or BIM
The folder icon has an arrow like a short cut with no expansion indicator in the tree node
Creating any roof element throws an error stating it cannot find the library part
Oneway
David Maudlin
Oneway:
In the US version, the RoofMaker Library 15 is inside the Object Library 15.lcf, so make sure that this library (Object Library 15) is loaded, or that the Object Library 15.lcf is inside the ArchiCAD Library 15 folder that is in your loaded libraries.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I uninstalled and reinstalled and it works fine now
